Discussion topic: Toob broadband, cant connect to skyQ
This message was authored by NicolaT1623 This message was authored by: NicolaT1623
Re: Toob broadband, cant connect to skyQ
Same issue here. So annoying.  Spoke to Toob today, who said Sky Q boxes can only run on the 2.4ghz channel and not the 5ghz channel.  You can ask Toob to assign the 2.4 channel to Sky box, they did this remotely for me.    However, we did this fix and we STILL have issues with the Sky box dropping connection to Toob almost right after we connect to Toob....its weird.
 We have tried numerous resets on both the Sky Q box and Toob router but our Sky box still can't maintain the connection to Toob for more than a few seconds.  Spoke to Sky call centre too, they couldn't assist either so now we've got to wait until 21/8 (the next available engineer visit). Not good at all.  Having read other forums, issues with Toob+Sky seem common.....
This message was authored by MBallin This message was authored by: MBallin
Sky engineer came today and was really good. Explained what had previously been mentioned about 2.4Ghz comparability only with third-party broadband equipment, vs 2.4 and 5.0 with Sky broadband. Was able to look at the "mesh" configuration of my setup and where there were weak spots or boosters/mini boxes prone to drop-out. Solved the "reach" with a newer booster in one room. To hopefully solve the drop off I was experiencing between Toob router (or "node" as he referred to it) he connected another Sky booster to the router via Ethernet so that all the sky equipment is running off other sky equipment rather than the Toob equipment. Now I wait to see if it all works but first indication is the WiFi speed has improved in previous weak spots.
