Discussion topic: To stuck on sky q intro
Message posted on 05 Jun 2023 08:15 PM
Recently reconnected my to after taking it off the wall to paint it, now my to is stuck on the sky q intro page and my remote is recognised by the tv to do anything with the sky q at all. The remotes work on the other tv's in the house but not this one
Message posted on 05 Jun 2023 08:32 PM
Re: To stuck on sky q intro
Try first rebooting the Q box.
If you can get the Q box on with green LED then you need try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
As highlighted above in bold the remote needs line of sight for pairing
Message posted on 14 Jul 2024 03:24 PM
I've done all the instructions above, when the Sky Q comes back on, it's at the "Accessibility on Sky Q" page. My remote isn't paired, so I can't click off this page to follow the instructions to pair the remote
how can I "Skip & Setup later"
Message posted on 14 Jul 2024 03:47 PM
@CptDarling wrote:I've done all the instructions above, when the Sky Q comes back on, it's at the "Accessibility on Sky Q" page. My remote isn't paired, so I can't click off this page to follow the instructions to pair the remote
Hi @CptDarling Are you sure that you completed the 7 & 9 four flashes and pointing the remote seeing (line of sight) the Sky Q box.
Message posted on 15 Jul 2024 12:45 PM
Yep. I get the 4 red lights, then press 1&3 but the remote isn't paired
