20 Dec 2023 05:40 PM
We had an out for 14 days, no internet, phone or apps on TV. Today it got reinstated, phone and internet working but cannot connect TV to Wi-Fi to get apps. Pass word is not accepted on the TV but works on other equipment.
20 Dec 2023 05:49 PM
Posted by a Superuser, not a Sky employee. Find out moreWhen you say TV do you mean Q box? (As many TV's can connect to internet too)
20 Dec 2023 05:56 PM
Hi @2+shoes
Are you carrying out a Network reset on your Q box exactly as follows:
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
