Discussion topic: To cancel an order
This message was authored by: Anthonyhankinso
To cancel an order
I have ordered a new sky q box but want to cancel
Re: To cancel an order
@Anthonyhankinso  You will need to call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
@Anthonyhankinso
As @GD1 you will need to call but as you may know there was a   problem with many SKY Q boxes which is likely to mean that the lines could be very busy still
