10
This discussion topic has been answered Discussion topic: Tnt hd not working
This message was authored by: Dmessiah
Tnt hd not working
Hi my tnt hd is not working says to watchbchannel I need to upgrade.but I have the channels I can watch on sd and uhd but not hd.iv read that satellite might need tweeking
Avatar for Dmessiah
This message was authored by: Dmessiah Answer
Re: Tnt hd not working
It's OK now I think the issue was when I upgraded through the sky app something went wrong.now with a new subscription I rang sky up to get new deal and uhd tnt is working now.so ring up instead of upgrading on app
This message was authored by: Lisa-P1987
Lisa - Sky Tech Team Expert
Avatar for Dmessiah
Still not fixed. Each time I put in watch wrong noone answers for hours then chat is closed.iv no tnt hd and I'm paying for it
@Dmessiah
Is the chat invite from the Messaging Team still live? You only have 48 hours to click on it and start the private chat or it will close automatically. If you fail to respond to a chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll need to check the chat thread periodically.
edit: @Dmessiah your other thread and posts have been deleted to prevent duplicate replies as you have this active thread.
Avatar for Dmessiah
There is no bubble for chat.still awaiting an answer
@Dmessiah
Unless you want the issue re-escalating you will need to call Sky.
Avatar for Dmessiah
Ok thanks
Very confusing these posts
This message was authored by: damien24
I have the same issue as the opening post, was there a resolution found for this?
This message was authored by: Marlu-Nyu
Are you subscribed to TNT Sports via BT? If so, you will need to contact TNT to upgrade your subscription. TNT Sports via BT only provided the SD version on their base price.
Sky Q (with Sky Cinema & Sky HD) • Sky Broadband (Fibre) • Sky Talk (VoIP)
Disney+ • Paramount+ • HBO Max • Discovery+
Avatar for Dmessiah
Avatar for Dmessiah
See my answer
