Discussion topic: Timber framed house
This message was authored by: gwn
Message posted on 03 Jun 2026 06:34 PM
Timber framed house
Moving house and found out the house is a timber framed house with brick outer built in 1990ish. Is it possible to fix a dish to this kind of house? Thanks
Message posted on 03 Jun 2026 06:41 PM
Re: Timber framed house
@gwn wrote:Moving house and found out the house is a timber framed house with brick outer built in 1990ish. Is it possible to fix a dish to this kind of house? Thanks
Yes, that'll be fine. The dishes Sky use are very light. Alternatively you could think about a streamed TV service instead which uses your broadband, then you don't need a dish at all.
