Discussion topic: Thought the no signal problem was fixed
Message posted on 24 May 2025 04:04 PM
Hello
Sky have had a problem with the signal and I received message saying it was fixed and got a sky store credit but today sky has gone off with signal problem four times today
When is this problem going to be resolved 😕
Message posted on 24 May 2025 04:07 PM
Re: Thought the no signal problem was fixed
Unlikely to be the same problem as last week.
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 24 May 2025 04:13 PM
@Karenlulu wrote:
Hello
Hi @Karenlulu
If it is shutting down try a Reset Settings in the main Q box hidden menu.
