Discussion topic: There is no volume from my mini box
Message posted on ‎30 Sep 2023 03:20 PM
There is no volume from my sky mini box which is still under warranty, I have swapped TVs and this did not resolve the issue
Message posted on ‎30 Sep 2023 04:30 PM - last edited: ‎30 Sep 2023 04:30 PM
Re: There is no volume from my mini box
hi @John104
Please can I suggest you check that the setting in :
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
is set to Normal
If it is, try toggling it to Dolby Digital then exit & then go back and set to Normal again
Message posted on ‎30 Sep 2023 04:31 PM
Hi @John104 The Mini box (also the Main box as well) does not have any volume control or in fact any sound output. The sound is from your TV or AV Amp.
Message posted on ‎30 Sep 2023 04:34 PM
