6
This discussion topic has been answered Discussion topic: Thats tv
This message was authored by: 0443
Thats tv
Thats tv was working on other channel section here in ireland now can not view it. The same with now 80s and 70s music channels and rewind tv.Does anyone know why ???
This message was authored by: xenon81 Answer
Re: Thats tv
@0443 wrote:
All other channels are there
but not the ones i mentioned
On Sky Q you will need to delete the current saved version of That's TV etc before retuning to the new one.
Re: Thats tv
hi @0443
use the following link for the latest frequencies &  paramaters
https://www.lyngsat.com/Astra-2E-2F-2G.html
Make sure you delete the  existing stored channels before trying to replace
Avatar for 0443
Re: Thats tv
Re: Thats tv
hi @0443
 I am not quite sure what you mean by not there.
Do you mean you have tried deleting and re-tuning and can't find them or something else ?
I can confirm the settings in the link I posted are correct - although I am in the UK & I am not sure whether they would be weaker in Ireland
Re: Thats tv
Re: Thats tv
@nigea99 wrote:
hi @0443
mmmm - is this not clear ?
Avatar for 0443
Re: Thats tv
I tune it on the sky q box all channels on that transponder are there but not all thats tv now 80s now 70s rewind tv
