17
This discussion topic has been answered Discussion topic: Tennis streams
This message was authored by: Karen1961
Tennis streams
I am trying to watch womens tennis from Wuhan.  For the last few days I cannot get into any of the streams and can only watch on the main sky channels (408 and 404).  I can get in as far as picking a match to watch but then it just hangs with the circle and nothing happens.
I got the sports package we are on specifically to watch tennis so can anyone help me
Avatar for Karen1961
This message was authored by: Karen1961 Answer
Re: Tennis streams
Hi Thanks for getting back to me.   yes i have tried the red button and going into sports listings.   I can get as far as the Wuhan tournament and list of live matches but when I click on an individual match it goes into it but when I hit the button for live feed it goes in and just buffers (spinning circle) and nothing else happens.   I am not very techie so wonder could you tell me how to do the reset that you mention on the end of your message.
Re: Tennis streams
@Karen1961
Is this on Sky Q, Glass or Stream ?
Re: Tennis streams
Sky Q (I think!).
Re: Tennis streams
@Karen1961 wrote:
Sky Q (I think!).
@Karen1961
Do you have a satellite dish (or connected to a communal dish) or is your TV service provided through the internet?
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Tennis streams
Re: Tennis streams
If that's the case then you have Sky Stream, not Sky Q.
Sky Stream is received via the Sky Stream puck, a small square box connected to your broadband and your TV. It relies entirely on you providing it with a fast and stable enough broadband connection in order to function.
You should test the speed actually being received by the puck - to do this, run a network check from the get help menu on the Netflix app on the puck. Sky recommend a minimum of 25Mbps for successful streaming.
Re: Tennis streams
Not aware of any issues for this tournament so far with the Sky Sports + streams for the WTA Wuhan Tennis.
The current live Sky sports streams for the Sky Sports + streams are working fine.
Use either;
The interactive coloured button, top right on your remote 🔴🟢🟡🔵 and select the stream there or select 'court choice' bottom right on screen, when it appears.
Scroll to Sports> Tennis, select Court choice or the live WTA Wuhan rail with live and upcoming events.
Say Tennis into your voice remote and do as above.
It might also be worth doing a settings restart of your Sky Stream puck or Sky Glass Tv.
Re: Tennis streams
Re: Tennis streams
@Karen1961
To do a settings restart:
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
A settings restart does more than just a power restart, it clears a number of areas of the local cache of the device, that may have built up over time.
it is  suggested to do a settings restart about once a week or fortnight, keeping it fresh.
Different ways to get to the settings menu;
Hit the . . . button on your remote and select settings, use voice saying 'settings' or scroll down to the settings menu on the home menu.
Re: Tennis streams
Hi again, when I go into settings there is no opton for Systems Management or to Restart...
Re: Tennis streams
If you do see what I mentioned, then you do not have Sky Stream or Sky Glass.
It was asked before on this thread.
Do you have Sky Q, meaning do you having a satellite dish?
Re: Tennis streams
Sorry for the confusion - I am not very well up on all this!  My husband is the TV expert but he is away.   I didnt think we had a satelite dish  but we do have SkyQ (I just checked).   As far as I know if our internet goes down we have no Sky TV so I thought that meant it came through our internet rather than satelite.
As it is SkyQ do you know what I should do to get the tennis stream back?
Thanks for your help so far.
Re: Tennis streams
I will pass this thread over to the Sky Q forum area, where someone with Sky Q can take you through the restart for you on Sky Q and see if that helps.
Re: Tennis streams
Thanks so much for your help and sorry for the confusion!   At least hopefully you have passed me onto someone who can help me!
Have a lovely day..
Re: Tennis streams
hi @Karen1961
Please can you look in:
And tell us which SKY Q box you have
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
