Discussion topic: Telly
Message posted on 02 Oct 2023 09:12 AM
Telly
My Sky Telly reads, it looks like you do not have Internet connection right now. If you've already set up will keep trying to connect. This has now been three days
Message posted on 02 Oct 2023 09:27 AM - last edited: 02 Oct 2023 09:39 AM
Re: Telly
@Lennyj If the message is from your TV you need to setup the TV to connect to your hub. You need to follow your TV's user guide.
If the message is from your Sky Q box have your tried these steps?
Message posted on 02 Oct 2023 09:33 AM - last edited: 02 Oct 2023 09:33 AM
Re: Telly
That's definitely a Sky Q message.
Try;
turning off minis, router and Q at mains
turn on router, wait 5 mins
turn on Q
does it connect?
If so, turn on minis
if not, try a network reset in the hidden installer menu (hover over settings and hit 001 Select)
