Discussion topic: Technical
This message was authored by: Gilla24
Technical
Hello my Sky switched itself off and when I switched it back on I can't get the internet back on. I cannot get mini Sky box on in the bedroom there is no internet coming on.
Re: Technical
Hi @Gilla24
Start by getting your main Q Box connected.
