Discussion topic: Technical problem
This message was authored by: M33lny
Technical problem
Just had sky Q fitted
the main box is working
the mini box shows thenicak fault please try later on all channels
Re: Technical problem
@M33lny Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
