Discussion topic: Technical issues
This message was authored by: KiraL
Message posted on 23 Apr 2025 08:27 PM
Technical issues
Our Sky Q box has stopped allowing us to download and also no longer shows recordings. If I try to download any new episodes it comes up with "because of a technical issue, your download could not be completed. Please try again later" It has been like this for the past 2 days. Any way of fixing this issue?
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 23 Apr 2025 09:34 PM
Re: Technical issues
@KiraL Have you tried rebooting your main Q box ie
Find out more
Message posted on 24 Apr 2025 07:07 AM
If the above restart does not solve your issue, try a reset of your hard drive as described here;
https://www.sky.com/help/articles/fix-recording-problems-on-sky-q-other-recordings-problems
Sky Community Superuser. What is a Superuser? Click here to find out
