Discussion topic: Technical issue
This message was authored by: Luke23
Technical issue
Can’t watch red button on sky sports says fault LAY1 anyone know how to fix ? Thanks
Re: Technical issue
Hi @Luke23
Instead of using the red button try selecting the match you need in the Home menu.
Home - Sports - Football
Avatar for Luke23
Level 0 icon
Re: Technical issue
Legend mate thank you. All sorted
