Discussion topic: Technical fault
This message was authored by: Jward
Technical fault
No skyQ . Says technical fault
Avatar for Jward
Level 0 icon
Re: Technical fault
Can't get sky to work
Re: Technical fault
Hi @Jward
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
