Discussion topic: Technical fault
This message was authored by: Dops987
Technical fault
Just had sky q box installed about an hour ago tv now not working saying technical fault
Re: Technical fault
Hi @Dops987
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for Dops987
Re: Technical fault just had q box installed about an hour ago now tv gone off message saying tecnic
just had sky q box fitted now no picture on tv message tecnical fault
@Dops987 have you followed the link that @oldfella supplied
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
