Discussion topic: Technical fault
This message was authored by: Pervaiziqbal
Message posted on 18 May 2024 10:05 AM
Technical fault
My satellite signal is not working on my sky box
Find out more
Message posted on 18 May 2024 10:39 AM
Re: Technical fault
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
