Discussion topic: Technical fault
This message was authored by: claude76
Technical fault
Hi technical fault on sky mini box it's all connected to internet etc showing this under settings have rebooted sky Q box and router as well still the same comes up technical fault on mini box don't even get tv guide showing can't watch recordings.
Re: Technical fault
Hi @claude76
Try a Reset Settings in the main Q box hidden menu.
Once the main  Q box is completely back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Avatar for claude76
Re: Technical fault
I have done above numerous times still same outcome
Re: Technical fault
@claude76
Have you reported this to Sky in the 6 months since you first posted about this? Bythe way your duplicate thread has been removed.
