Discussion topic: Technical Fault
This message was authored by: Nic61
Technical Fault
Hi
Both Sky Q minis show a technical fault
Re: Technical Fault
@Nic61 wrote:
Hi
@Nic61 Have you tried rebooting your main Q box ie
then
reboot reach mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Nic61
Re: Technical Fault
Thanks for rescuing. I've actually tried that and also factory reset  both mini boxes. New ones being sent out now.
