Discussion topic: Tech issue on all channels
This message was authored by: Ash196
For a week now the tv has worked intermittently.  It is pixelating and then eventually the screen goes blank and 'There is a technical issue with this channel' appears.  This is on all channels, but the tv schedule still appears and I can watch recordings and apps.  Sometimes the screen goes blue and the tv schedule disappears too.  I have rebooted the router and the sky q box.  I have also done a soft reset on the sky q box to no avail.
Re: Tech issue on all channels
Hi @Ash196
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for Ash196
I have already followed this, but thank you
Hi @Ash196
If you have been through the link and haven't solved your issue then there is a conclusion!
