This discussion topic has been answered Discussion topic: TV stuck on settings screen
Message posted on 26 Jan 2026 03:40 PM
I was watching a recording when the screen froze. Rebooted box and Tv, went through sky chat to do a reset and now the screen is stuck on "Accessibility on Sky Q"
cannot get out of it.
also skyQ box has to be switched on manually remote won't do it but works for the Tv?
Message posted on 26 Jan 2026 04:15 PM
This Accessibility screen issue comes up quite often. Sky have previously suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 26 Jan 2026 03:46 PM
Re: TV stuck on settings screen
Re-pair the remote, as per the online guide on the sky site
Message posted on 26 Jan 2026 05:33 PM
Thank you - it worked!!
