Discussion topic: TV not working properly
This message was authored by: ND1975
Message posted on 19 Nov 2025 06:54 PM
New sky set up, all fine on main sky box, but the multi room box isn't showing any apps.
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Nov 2025 09:45 PM
Re: TV not working properly
@ND1975 you could try refreshing the apps in the engineers menu on the mini box
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
This can take upto 24 hours but normally takes less time than this
