Discussion topic: TV has no internet connection
Message posted on 30 Oct 2025 08:32 PM
It says it has network connection but no internet how is that possible
Message posted on 30 Oct 2025 09:20 PM
Re: TV has no internet connection
@Tiredofsame Is this on your actual TV or Sky Q box?
Message posted on 30 Oct 2025 09:45 PM
Hi @Tiredofsame
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 01 Nov 2025 03:06 PM
thanks so much. solved our problem
