Discussion topic: TV connectivity is very patchy on mini box
This message was authored by: DC+71
Over last couple of days the tv on a minibox has become very patchy to the point of being unusable (is pertty much off 50% of the time).  Occassionally it says there is a technical fault other times it is just blank. Have rebooted/reset numerous times - bith Sky Q box and mini box - including taking card in and out.
One observation is that it takes longer for a change of channel to be processed remaining blank for a period of time.
This message was authored by: Lucky66p
Re: TV connectivity is very patchy on mini box
Mine is doing the same, have you had any response?
Avatar for DC+71
Nothing yet
Avatar for DC+71
Q box playing up significntly now
Hi @DC+71
Try a Reset Settings in the main  Q box hidden menu.
  • All good now
Avatar for DC+71
Thanks have  tried hidden reset just now on q box - still same results after restart. Looking at a blue screen and technical fault with channel message on mini box tv right now - will disappear after I change in and out of channel. Still notably slow when changing between channels.
This message was authored by: Woody1063
Mine is doing the same too.
