Discussion topic: TV NOT CONNECTING TO BROADBAND OR INTERNET
This message was authored by: AnnLA
Morning we have never had any problems with our Sky Q box, but for the last week or two  it has not been connecting to broadband or internet. I have tried all the recommended remedies but it sometimes connects the drops out. We have SKY broadband . All other devices in our home are still connecting to our Sky router with no problem.
This message was authored by: Barlow62
Re: TV NOT CONNECTING TO BROADBAND OR INTERNET
same
Hi @AnnLA
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max ) router then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
