Discussion topic: TNT sport
This message was authored by: ROB23fsdfsd
TNT sport
I've just paid for TNT sport but when I try to go into the channel it states no satalite signal, though I am receiving all other sky chanels
Re: TNT sport
@ROB23fsdfsd
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
