Discussion topic: TNT Sports in HD
This message was authored by: CD98
TNT Sports in HD
Hi
I got my sky Q installed yesterday, everything working fine apart from TNT sports not coming in in HD, I have TNT sports 1 in HD but 2,3 and 4 or only in SD and the HD versions are telling me I need to subscribe however when I do this it tells me I am already subscribed.
software is up to date and every other channel works fine in HD
Re: TNT Sports in HD
@CD98 wrote:
Hi
@CD98 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for CD98
Tried this and no luck
Hi @CD98   As a work-a-round, before it is sorted, you should be able to use Discovery+.
