Discussion topic: Susan Hunt
Message posted on 31 Jul 2025 09:58 AM
Susan Hunt
I have been unable to watch my mini box since 18/7, initially there was a serious. fault with Openreach but our internet was restored on Monday but despite conversations with the help desk who tried to solve the problem but 15minutes after we ended the call the minibox lost the connection to the Q box.
The system shows there is still a fault but no suggestion when it might be solve.
I hope this issued will be solved soon, I assume I will receive compensation at some stage for an issue that has now gone on far to long.
Message posted on 31 Jul 2025 10:37 AM
Re: Susan Hunt
Hi @Sue+Wife
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
