Discussion topic: Stuttering Sky
This message was authored by: elthompo27
Stuttering Sky
Hi all.
Has anyone noticed recently a lot of Sky channels have started to stutter?
I'm watching the Community Shield on ITV and every now and again it keeps stuttering?
Has anybody else experienced this.
Cheers
Re: Stuttering Sky
@elthompo27 wrote:
Hi all.
Cheers
@elthompo27 do you have your own dish or are you on a communual dish ?
Avatar for elthompo27
Level 2 icon
Re: Stuttering Sky
My own dish?
This message was authored by: ftballman
Re: Stuttering Sky
Interesting. I watched on Premier sports (Ireland) which is just a simulcast of ITV's coverage. I noticed a number of sound stutters and a smaller number of picture stutters.
I had assumed it was premier's issue but obviously not.
Overall with the issue you mentioned are you seeing the issue just on the same channel or a mix?
Re: Stuttering Sky
@elthompo27 wrote:
My own dish?
@elthompo27 I would hazzard a guess if you are not seeing this on any other channel and with @ftballman seeing similiar albeit on a simulcast that it may just have been a blip on the ITV broadcast
This message was authored by: Paul680
Re: Stuttering Sky
Yes we have been experiencing the same today too, not great. Also at times the picture has a magenta tinge to it as well.
No idea as cannot be weather, as there is not a cloud in the sky,
Re: Stuttering Sky
@Paul680 Have you tried rebooting your main Q box ie
