2
This discussion topic has been answered Discussion topic: Staying on yellow
This message was authored by: skelly12
Staying on yellow
Sky box light staying on yellow after pressing house
Re: Staying on yellow
Hi @skelly12
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @skelly12
Avatar for skelly12
All Sorted thank you 🤩
