Discussion topic: Status = Satellite signal unlocked?
Message posted on 28 Apr 2024 05:19 PM
No satellite signal
status is showing satellite signal unlocked
gone through all the advice reboot/ checking connections etc
Message posted on 28 Apr 2024 06:11 PM - last edited: 28 Apr 2024 06:21 PM
Re: Status = Satellite signal unlocked?
That's a bad thing: it indicates the dish is not receiving an appropriate signal (as in 'locked on target')
You'll need to book a fault with Sky to get an installer to attend and check the dish alignment.
Message posted on 24 Jun 2024 06:19 PM
Satellite signal to multi room not working
Message posted on 24 Jun 2024 06:35 PM
@Kathy20 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jun 2024 12:02 PM
Thank you Kathy, that fixed my problem 😊
Message posted on 16 Nov 2024 11:48 AM
I have no satellite signal. It says, Satellite Signal Unlocked. can anyone help, please?
Message posted on 16 Nov 2024 01:29 PM
@Imoh07 try following the link below
