Discussion topic: Standby mode
Message posted on 30 Aug 2026 02:46 PM
Standby mode
My Sky Q Box constantly on standby. Changed remote battery.
Manually press button on box, doesn't change, still on standby.
Can anyone advise?
Message posted on 30 Aug 2026 03:30 PM
Re: Standby mode
Hi @Conza1965 Have you tried a power reboot?
Message posted on 30 Aug 2026 04:21 PM
Re: Standby mode
Yes. Still no joy. Cheers
Message posted on 30 Aug 2026 08:32 PM
Re: Standby mode
Can anyone advise?
Hi @Conza1965
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
