Discussion topic: Sports Chanel’s not working
Message posted on 28 Feb 2025 06:05 PM
All my TNT and premier sports channels come up with an error when I try to watch them: 'This channel is currently affected by a problem with your satellite signal.
ALL other channels are working perfectly. I checked SKy go and they work on my mobile. I have checked the satellite signal and it's perfect. Have rebooted both sky boxes 4 times and it's the same error message.
Message posted on 28 Feb 2025 06:06 PM
Re: Sports Chanel’s not working
@lennontim
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
