Discussion topic: Spider Noir - cannot select format on Q mini box
This message was authored by: khy+iorhiogthio
Hi
We are unable to select the colour/b&w option on Spider Noir on the Amazon Prime app on Sky Q mini box.
when we press select to play it presents both options but we can't choose - both are highlighted white.
Anyone else had same issue or now how to select?
This message was authored by: Jason-m
Re: Spider Noir - cannot select format on Q mini box
I have exactly the same problem with sky +
It works on prime app on tablet
It works via fire stick in another tv with app
It works via app on smart tv
There the problem is sky's.
This message was authored by: Wescross
Yup same here. I can only watch in black and white. No option to change over.
This message was authored by: HarambeTheWhite
Experiencing the same issue ...not sure how to force an app update but I imagine this is the issue... let me know if you sort it
I've done that but can take 24hours to update.
Go to settings type 001 and select then you can hit refresh apps.
Guess I'll now tomorrow if it's worked.
imho we should in the sky settings be able to see the app version.
This message was authored by: PhilGst
App update didn't make any difference to me
This message was authored by: Timbolo
A Sky Q software update fixed this problem for me. Press Home on your Sky Q remote and navigate to Settings > System info. Highlight Software version, select Setup, and choose Software download. The download will take about 10 minutes. Put the box in Standby to complete the installation.
