Discussion topic: Sound keeps dropping out
Message posted on 08 Nov 2024 03:01 PM
In last couple of days sound keeps dropping out for a second. It happens on all Sky channels. Didn't do it previously. TV and Sound bar are a month old. Haven't changed settings. Tried all usual fixes and it's still doing it. This had been reported previously. It's a Sky issue !
Message posted on 08 Nov 2024 03:17 PM
Re: Sound keeps dropping out
Message posted on 08 Nov 2024 03:21 PM
I knew that reply was coming. I've tried it all!!!
