Discussion topic: Sound issue
Message posted on 14 Nov 2024 09:10 PM
Sound issue
I got sky Q last week after previously having sky+ What I've noticed three times now is when I fast forward a recording to skip the adverts when I press play the sound us gone totally. I rewind back a touch press play again and it's back. Anyone know why please. It's on my mini box.
Message posted on 14 Nov 2024 09:12 PM
Re: Sound issue
Hi @Chigirlx
Reboot the mini as above.
Message posted on 14 Nov 2024 09:17 PM
Re: Sound issue
Thanks I'll try that tomorrow as someone is using the main box. Will recordings still be there afterwards
Re: Sound issue
