This discussion topic has been answered Discussion topic: Sound Bar Connectivity to Sky Q by Bluetooth
Message posted on 29 Aug 2023 07:39 PM
My Hitachi sound bar has Bluetooth connectivity, but no display screen or keyboard by which to enter the box's Bluetooth authentication codes. (Setup>Settings>Music>Add a device....>)
Normally, the bar is 'discovered' by the TV (once powered up), but the viewer is challenged by the TV to validate its Bluetooth connection). I would prefer to just connect to the SKY Q box, but I cannot authenticate.
Suggestions?
Message posted on 29 Aug 2023 09:24 PM
Hi @Julian54 I assume you mean pair your iPhone to the Sky Q box for audio. The Sky Q box has a Bluetooth receiver for this. Just no transmitter.
Message posted on 29 Aug 2023 07:41 PM
							Re: Sound Bar Connectivity to Sky Q by Bluetooth
Hi @Julian54 I'm afraid that there is no A2DP transmitter included in the Sky Q box so connecting a sound bar by Bluetooth is impossible.
Message posted on 29 Aug 2023 08:01 PM
...but I can connect my iPhoneto the SKY Q via Bluetooth, no way to emulate that for a sound bar?
Message posted on 30 Aug 2023 08:11 PM
Thanks, I will verify tomorrow
Message posted on 04 Sep 2023 07:07 PM
That's correct. However, I located the original optical cable for Hitachi sound bar, so no need for Bluetoot any longer 🙂
