Discussion topic: Some channels arnt working
This message was authored by: Kerry165
Some channels I can't get
Re: Some channels arnt working
Do you have a subscription for them?
Avatar for Kerry165
Level 0 icon
Yes I have the full subscription
@Kerry165
Which channel(s)?
Whats happening when you try to view them?
Avatar for Kerry165
Level 0 icon
It's saying no signal
@Kerry165
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
