1
This discussion topic has been answered Discussion topic: Skyminboxntcnnctig
This message was authored by: Gary296
Skyminboxntcnnctig
Sky mini box is not staying connected
Re: Skyminboxntcnnctig
Hi @Gary296
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @Gary296
