Discussion topic: Skybox
Message posted on 29 Jun 2023 02:25 PM
Skybox
My sky box keeps freezing
Message posted on 29 Jun 2023 03:04 PM
Re: Skybox
Hi @Brodie3
If this is the main Q box Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 17 Dec 2023 04:42 PM
Re: Skybox
I have one main sky Q and 2 x min box's, one of the min box's keeps freezing during live tv on sky and recordings pause while playing. There is also loss of sound. Not sure if this is related but we recently had a new Sky router installed. I've reset the min box numerous times but no joy. Netflix, Disney etc. are all fine. Any suggestions?
Message posted on 17 Dec 2023 04:56 PM
Re: Skybox
@Blade2260 try rebooting your router whe that is up and running
reboot your main Q box ie
then finally
reboot your mini box
