Discussion topic: Skybox over heating
Message posted on 12 Aug 2023 08:42 AM
Skybox over heating
Sky Box extremely hot and I am concerned it will catch fire.
Message posted on 12 Aug 2023 08:58 AM
Re: Skybox over heating
Hi @SJE1 SKY Q boxes are designed to let heat dissipate from the inside through the case, however the case should not be too hot that you cannot place your hand on it?
Message posted on 12 Aug 2023 09:08 AM
@SJE1 Is the box getting plenty of ventilation? It needs good air flow around it and not the be sat in an enclosed space/cupboard or on top of other appliances that give off heat such as a hifi unit, TV etc.
