Discussion topic: SkyQ mini boxes not working
Message posted on 12 Jul 2023 06:58 PM
My skyQ mini boxes are not working. There is a message saying they are not receiving satellite signal.
The main SkyQ box is working.
I have ran through checking that the mini boxes are connected to the main box and that they have a tick for internet connection.
How do I fix this issue?
Message posted on 12 Jul 2023 07:15 PM
Re: SkyQ mini boxes not working
Hi @LORNA100
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the minis as above.
If the minis still does not connect try a Network Reset on the minis. Start with the one nearest to the main Q box.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
With the network reset on the second mini you use the first mini or the main Q box or the Sky router (if on Sky Broadband) for the WPS. Use whichever is nearest.
Message posted on 12 Jul 2023 07:37 PM
Hi @oldfella
Unfortunately, that hasn't worked, but thanks for trying to help.
Message posted on 12 Jul 2023 07:53 PM
