Discussion topic: SkyQ box keeps switching off
This message was authored by: Ydzmwjjsmau
SkyQ box keeps switching off. Having to remove power cable and go through start up process way too often
Re: SkyQ box keeps switching off
Hi @Ydzmwjjsmau
