Discussion topic: SkyQ apps keep freezing
Message posted on 17 Feb 2025 09:55 AM
Skyq apps, particularly ITVX, keep switching off during programs. 10 minutes in, screen goes blank and have to press the TV button and start again...
Message posted on 17 Feb 2025 05:01 PM
Re: SkyQ apps keep freezing
@SAC1969 Have you tried rebooting your main Q box ie
or
if that doesnt work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
