2
This discussion topic has been answered Discussion topic: SkyQ-Recording
This message was authored by: NeilHa
SkyQ-Recording
I have a new SkyQ box which is suitable for UHD broadcast. It works fine except I cant record. I have contacted Sky rechnical dept and both times they have paired it with my sky card and it has worked for one day then the recording facility stops working. Does anyone have any ideas or should i book an engineer?
Avatar for NeilHa
This message was authored by: NeilHa Answer
Re: SkyQ-Recording
Thank you for your advice, which I followed. Unfortunately the problem persisted so I called Sky Tech Dept and they came and installed a new SkyQ box as they found the original to be faulty.
Re: SkyQ-Recording
Hi @NeilHa
Failing this then you need to contact Sky.
Avatar for NeilHa
Re: SkyQ-Recording
