This discussion topic has been answered Discussion topic: Sky
Message posted on 05 Feb 2026 07:40 PM
I can't get sky Atlantic it's saying I need to press red button to upgrade I'm already paying for it
Message posted on 05 Feb 2026 07:48 PM
@Donna240 Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to watch/download the programme in HD try finding the SD version of the channel
or
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
or
