Discussion topic: Sky
Message posted on 09 Dec 2023 06:03 PM
Sky
Sky q mini box won't connect
Message posted on 09 Dec 2023 06:05 PM
Re: Sky
Sky q mini box won't connect error MR102
Message posted on 09 Dec 2023 06:07 PM
Re: Sky
Hi @JoSavidge
Reboot the mini as above.
Message posted on 09 Dec 2023 07:00 PM
Re: Sky
Won't obtain ip address
Message posted on 09 Dec 2023 07:02 PM
Re: Sky
Message posted on 09 Dec 2023 07:16 PM
Re: Sky
It seems to have sorted itself thank you x
