Discussion topic: Sky voice remote not working on my sky Q
This message was authored by Bintou This message was authored by: Bintou
I bought a sky Q  voice remote but only the power button works, everything else not working including input and volume buttons.
Re: Sky voice remote not working on my sky Q
Hi @Bintou
First reboot theQbox
Wait at least 30 secs and then Plug back in and switch your Q box back on at the mains.
Then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Bintou
Hi, this still doesn't work, only the power key works but the rest aren't.
Hi @Bintou
The Red led on the remote should light when you press the Microphone button or the Question mark button.
Looks like the remote could be faulty.
Bintou
It's a brand new remote, just got it this morning.
This message was authored by bob1234 This message was authored by: bob1234
@BintouIf you have tried everything listed in the link below, if you bought it from Sky phone them to get a replacement, if you bought it from somewhere else you will have to go back to them.
Try this link for help with your Q remotes
https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with.
