2
This discussion topic has been answered Discussion topic: Sky upstairs box keeps freezing
This message was authored by: Janette91162
My upstairs sky q box keeps freezing especially at night
Re: Sky upstairs box keeps freezing
Hi @Janette91162
Looks like poor connectivity.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
If you still experience issues you may need a Sky Q booster positioned midway between the main Q box and the mini.
Hi @Janette91162
Avatar for Janette91162
Thank you
